Brazed-plate heat exchangers
Brazepak heat exchangers feature stainless-steel 316L plates and are suited to refrigerant condensers and evaporators and as oil coolers for engines and machinery. They operate in temperatures of 310° to 435° F and are rated for pressures to ...
Brazepak heat exchangers feature stainless-steel 316L plates and are suited to refrigerant condensers and evaporators and as oil coolers for engines and machinery. They operate in temperatures of 310° to 435° F and are rated for pressures to 435 psig and flows of 800 gpm. Connections range from 1/2 to 4 in. with options of NPT, SAE, flanged, and sweat types.
ITT Standard, (800) 447-7700, www.ittstandard.com
