Particle Counter
The CML is a portable, accurate instrument-suitable for 'on-site' applications. It can automatically measure and display particulate contamination, moisture and temperature levels in various hydraulic fluids.
CML2 and CML2W series portable particle counters are designed for use with LPA View software and a main electrical power supply (12 to 24 Vdc, 1 A maximum). They measure and quantify the numbers of solid contaminants in hydraulic, lubrication, and transmission applications and use mineral oil as operating fluid; CML2W also measures percent of water saturation in oil and temperature. They can be used to 400 bar/6000 psi and feature better than 3% accuracy.MP Filtri USA, (215) 529-1300,www.mpfiltriusa.com
