Hand-held oil meter
Humicap MM70 moisture meter quickly and efficiently measures moisture content of oil. Measurement is reported as wateractivity, which accurately indicates the margin to free water formation within oil. Probewithstands pressure of 150 psig. Ball valve ...
Humicap MM70 moisture meter quickly and efficiently measures moisture content of oil. Measurement is reported as wateractivity, which accurately indicates the margin to free water formation within oil. Probewithstands pressure of 150 psig. Ball valve allows the probe to be inserted directly into apressurized pipe or vessel. Sensor is compatible with most types of oil and hydraulic fluid. Itfeatures a menu-based, graphical user interface and a backlit LCD.
Vaisala Inc., (888) 824-7252, www.vaisala.com
