Expansion CV plugs
Expansion CV plugs seal holes in manifolds and castings. Single-piece assemblies range from 3 to 22 mm. Feature stainless steel, carbon steel, aluminum, brass, and other materials. Burst pressures to 40,000 psi. No threading or reaming required. ...
Expansion CV plugs seal holes in manifolds and castings. Single-piece assemblies range from 3 to 22 mm. Feature stainless steel, carbon steel, aluminum, brass, and other materials. Burst pressures to 40,000 psi. No threading or reaming required. Installation into as-drilled holes offers leak-tight seal without use of Locktite, pipe dope, or other sealants.
Farmington Engineering Inc., (203) 245-1100, www.farmingtoneng.com
