Hermetic pressure transducers
A dry hermetic transducer (DHT) offers pressure ranges from 50 to 750 psi. All stainless-steel casing is environmentally sealed to protect the non-drift ceramic, capacitive sensing element from contaminants. Welded hermetic seal improves ...
A dry hermetic transducer (DHT) offers pressure ranges from 50 to 750 psi. All stainless-steel casing is environmentally sealed to protect the non-drift ceramic, capacitive sensing element from contaminants. Welded hermetic seal improves vibration tolerances, rated at 20 g. Available in 4-20-mA and voltage outputs. Highly accurate to 0.25 BFSL, repeatability of 0.1%, and EMC protection to 100 V/m.
Texas Instruments Sensors and Controls
(888) 438-2214
www.tisensors.com
