Pumps and compressors
Line of single and double piston pumps and compressors withstands extremely demanding applications. Comprised of the 660/668 and 2660/2668 series, these pumps and compressors feature air flows to 5.25 cfm (149 lpm), pressures to 160 psi (11 bar) and maximum vacuum to 99% of local barometer (990 mbar). Die-cast aluminum parts are strong, lightweight and durable.
Line of single and double piston pumps and compressors withstands extremely demanding applications. Comprised of the 660/668 and 2660/2668 series, these pumps and compressors feature air flows to 5.25 cfm (149 lpm), pressures to 160 psi (11 bar) and maximum vacuum to 99% of local barometer (990 mbar). Die-cast aluminum parts are strong, lightweight and durable. In addition to low vibration and reduced sound level, oil-less WOB-L technology extends operating life.
Thomas Division, a Gardner Denver Co., (920) 457-4891, www.gd-thomas.com
