Vacuum generators
JB Series single-stage vacuum generators are versatile, air-powered vacuum pumps with no internal moving parts and can achieve vacuum levels to 27-in. Hg. Straight-through internal design won't easily clog and can be reverse blown to clear if ...
JB Series single-stage vacuum generators are versatile, air-powered vacuum pumps with no internal moving parts and can achieve vacuum levels to 27-in. Hg. Straight-through internal design won't easily clog and can be reverse blown to clear if needed. Controlled by manual or automatic valve on compressed air line. Operate on 50 µm filtered, nonlubricated 72.5 psi air. Five standard sizes from 0.76 to 1.34 OD.
Anver Corp., (800) 654-3500, www.anver.com
