Piston pumps
Versatile 1207 series WOB-L piston pumps provide an oil-less, non-lube piston and cylinder for long life and clean air flow. Flow up to 4.3 cfm, pressure to 125 psi, and vacuum to 28 in.-hg. Feature stainless steel valves, hard-coated aluminum ...
Versatile 1207 series WOB-L piston pumps provide an oil-less, non-lube piston and cylinder for long life and clean air flow. Flow up to 4.3 cfm, pressure to 125 psi, and vacuum to 28 in.-hg. Feature stainless steel valves, hard-coated aluminum cylinder, and polytetrafluoroethylene teflon piston seals. Powered by capacitor-start ac motors of airover design.
Rietschle Thomas Sheboygan
(920) 457-4891
www.rtpumps.com
