Make pneumatics quieter and cleaner — it's the law
For decades, air exhaust mufflers have been used to reduce noise and emissions of compressed air exhausts. But exhaust mufflers have taken on greater importance with the ...
For decades, air exhaust mufflers have been used to reduce noise and emissions of compressed air exhausts. But exhaust mufflers have taken on greater importance with the enactment of OSHA (Occupational Safety and Health Administration) Standard 1910.1000. In part, the standard mandates that noise may not exceed 90 dBA during an 8-hr day of a 40-hr week.
But regulations go one step further by spelling out noise and emissions limits allowed for specific durations. For example, exhaust noise from a pneumatic system as high as 115 dBA is acceptable. However, workers may only be exposed to this noise for 15 min within an 8-hr shift. So if workers will be near the exhaust of a pneumatic system for an entire 8-hr shift, noise to only 90 dBA is allowed.
As far as emissions go, compressed air exhaust may not exceed 4.32 ppm of oil mist contamination in any 8-hr work shift of a 40-hr work week. Manufacturers state that this level can be achieved easily with a coalescing muffler, which typically reduces emissions to 0.015 ppm. Without coalescing mufflers, contamination as high as 50 ppm or more may exist in a plant that is tightly closed for operation in cold weather. Internal geometry to reduce air velocity and baffles for audio damping take care of noise; filtration takes care of the oil. But just any filter-muffler may not suffice.
A standard filter-muffler has a porous element to trap any solids that may have been entrained in the com-pressed air stream. Porous elements, however, are not designed to trap oil vapors. So unless the pneumatic system uses an oil-free air compressor and no lubricators, exhaust air should be routed through a coalescing muffler.
A coalescing muffler operates on the same principles as a coalescing filter. As air flows through the coalescing element, oil particles are captured by three different mechanisms: direct interception, inertial impaction, and diffusion. In direct interception, oil particles simply collide with and are trapped by filter fibers. With inertial impaction, the element's turbulent air stream throws oil particles against fibers, which trap the oil. Diffusion causes the smallest particles to vibrate and collide with each other — and eventually the element's fibers - which traps the oil.
Whatever the choice, mufflers that remove oil from the exhaust air should be considered - especially if air exhausts near workers. It is not uncommon for coalescing mufflers to remove 99.97% of the entrained oil. Even if oil-free compressors are used, exhaust mufflers can reduce noise to OSHA-acceptable levels and ensure that exhausted air is clean.
