Solenoid valve
Solenoid valve EVP Series proportional control valve uses a single internal moving part for precise control of air and inert gases. The valve can be controlled using dc, open or closed-loop control, or pulsewidth modulation. The valve offers ...
Solenoid valve
EVP Series proportional control valve uses a single internal moving part for precise control of air and inert gases. The valve can be controlled using dc, open or closed-loop control, or pulsewidth modulation. The valve offers many options, including mounting, ports, and seal material. Five orifice sizes are available: 0.009, 0.013, 0.025, 0.040, and 0.060 in.It is rated for pressures to 100 psig and temperatures from 32° to 120°F (0° to 50°C) and is available with #10-32 female (in-line) or #10-32 male stud (manifold) ports.
It offers long life and low power, and varies the output flow based on the current input to the solenoid. The consistent gain of this valve provides a high degree of control for many applications.
Seal materials include Buna-N, Fluorocarbon, EPDM, and others.
Clippard Instrument Laboratory Inc.
(877) 245-6247
www.clippard.com
