Pressure regulators
Rotork Fairchild has deisgned a new range of compact high pressure pneumatic regulators for instrument and industrial applications. Constructed with 316 stainless steel bodies, the units are available as the HPD diaphragm design for pressures up to 6000 psi.
High pressure regulator
Rotork Fairchild has deisgned a new range of compact high pressure pneumatic regulators for instrument and industrial applications. Constructed with 316 stainless steel bodies, the units are available as the HPD diaphragm design for pressures up to 6000 psi. Regulators are available with the standard polymer valve seat for media temperatures up to 80ºC and supply pressures up to 35000 psi. Both the HPD and HPP designs are available with 6mm(1/4") ports in either 2 or 4 port configurations and in multiple output pressure ranges. Standard knobs can be replaced with tamper proof caps and regulators can be mounted at the ports, the bottom surface or in panel mounted configurations.
Rotork Fairchild, (800)334-8422, www.fairchildproducts.com
