Plug-in air valves
Edited by Mary C. Gannon Centralized Isys Micro plug-in valve system lets users choose from various installation configurations, communications protocols, and override systems when building compact pneumatic systems. Metal subbase can be fitted with ...
Centralized Isys Micro plug-in valve system lets users choose from various installation configurations, communications protocols, and override systems when building compact pneumatic systems. Metal subbase can be fitted with up to four valves. Compact back-to-back design uses four solenoid valves in each 42-mm-wide slice producing up to eight functions/module. It uses front or bottom-ported modules and requires no individual wiring.
Parker Hannifin
(216) 896-3000
www.parker.com
