Rotary air valves
Rotary air valves feature 4-way configuration with 14 -in. NPT ports and a corrosion-resistant anodized aluminum body. They are manually shifted with a 3-position, closed center design and accommodate pressure to 150 psig at operating ...
Rotary air valves feature 4-way configuration with 14 -in. NPT ports and a corrosion-resistant anodized aluminum body. They are manually shifted with a 3-position, closed center design and accommodate pressure to 150 psig at operating temperatures from 32° to 140°F. They feature a small footprint and can be base-mounted.
Clippard Instrument Laboratory Inc.
(877) 245-6247
www.clippard.com/rotaryvalves-h
