Blow gun
Edited By Mary C. Gannon Typhoon blow gun is available with 45 bent angle safety tips to get into hard to reach areas. Tip swivels so it can be rotated to desired position and then locked in place. Tips are available as 12-, 24-, 36- and 48-in. ...
Typhoon blow gun is available with 45 bent angle safety tips to get into hard to reach areas. Tip swivels so it can be rotated to desired position and then locked in place. Tips are available as 12-, 24-, 36- and 48-in. length extensions. High volume blow-off capacity can be controlled by the variable control trigger, making it equally effective for large and small particle removal.
Coilhose Pneumatics, (732) 390-8480, www.coilhose.com
