Air switches
MV Series three-way air switches eliminate the need for wire shielding, transformers, and solenoids. The 1 /8-in. ported air pilot valves are identical in size, actuating style, and mounting qualities to most industrial electrical limit ...
MV Series three-way air switches eliminate the need for wire shielding, transformers, and solenoids. The 1 /8-in. ported air pilot valves are identical in size, actuating style, and mounting qualities to most industrial electrical limit switches. Can be installed as normally open, normally closed, or as diverters. Available with options using brass fittings.
Mead Fluid Dynamics, (773) 685-6800, www.mead-usa.com
