Brass ball valves
BV2MB brass ball valves are available in 1/4 to 3 in. NPT sizes suited for water shut-off applications. Two-piece ball valve has Teflon seats for wear resistance and full port design for maximum Cv with minimal pressure drop and bubble-tight ...
BV2MB brass ball valves are available in 1/4 to 3 in. NPT sizes suited for water shut-off applications. Two-piece ball valve has Teflon seats for wear resistance and full port design for maximum Cv with minimal pressure drop and bubble-tight shut-off to 600 psi. Blow-out proof stem provides safety from overpressure.
W.E. Anderson, Div. of Dwyer Instruments Inc., (219) 879-8000, www.dwyer-inst.com
