Solenoid poppet valves
The 315L/415L series latching poppet valves have a single direct-acting solenoid that is designed for reliable operation. Pressure range from vacuum to 125 psig. Flexible 3- and 4-way porting configurations available with 1/8 NPSF ports for ...
The 315L/415L series latching poppet valves have a single direct-acting solenoid that is designed for reliable operation. Pressure range from vacuum to 125 psig. Flexible 3- and 4-way porting configurations available with 1/8 NPSF ports for in-line mounting on standard and custom manifolds. Momentary signal changes position, while magnetic latching mechanism maintains position.
Humphrey Products Co.
(269) 381-5500
www.humphrey-products.com
