Solenoid Valve
The 3835 2 or 3-way, 2-position direct pilot solenoid valve is a drop-in replacement for mounting. It is available in sizes from 0.6 to 3 mm in normally open and closed configurations and is rated for flows of 0.025 to 0.31 ...
The 3835 2 or 3-way, 2-position direct pilot solenoid valve is a drop-in replacement for mounting. It is available in sizes from 0.6 to 3 mm in normally open and closed configurations and is rated for flows of 0.025 to 0.31 Cv and pressures to 200 psi. Current consumption ranges from 0.9 to 10 W. Available elastomers include Viton, nitrile, EPDM, and Chemraz.
Spartan Scientific
(330) 758-8446
www.spartanscientific.com
