Pneumatic valves
TC08 and TC15 valves provide flow rates of 0.8 and 1.5 CV, and are 17 or 21 mm wide, respectively. Single valves can be flange-mounted to any flat surface, and modular manifold system has up to 12 valve positions. They come with choice of inch ...
TC08 and TC15 valves provide flow rates of 0.8 and 1.5 CV, and are 17 or 21 mm wide, respectively. Single valves can be flange-mounted to any flat surface, and modular manifold system has up to 12 valve positions. They come with choice of inch ( and …-in. NPT) or ISO-G (G and G…) ports. Valve manifold has low height because it does not need subbases. Bosch Rexroth Corp., Pneumatics Technology Group, (859) 259-3852, www.boschrexroth-us.com/brp
