Membrane air dryers
PISOO Fiber Dry membrane-type dryers are compact and suit portable devices or compact equipment. Air-flow varies from 1.4 to 17 scfm. They achieve dew point of 13° F or below. Hollow dryer does not require electric power and produces no drainage ...
PISOO Fiber Dry membrane-type dryers are compact and suit portable devices or compact equipment. Air-flow varies from 1.4 to 17 scfm. They achieve dew point of 13° F or below. Hollow dryer does not require electric power and produces no drainage because removed moisture is discharged as vapor.
Pisco USA Inc., (630) 521-9920, www.pisco.com
