Multiple regulator mounting
Up to four QB3 electronic pressure regulators can mount on a manifold, offering a common supply and exhaust port with individually controlled ports to minimize plumbing. The regulators electronically control pressure or vacuum by accepting a ...
Up to four QB3 electronic pressure regulators can mount on a manifold, offering a common supply and exhaust port with individually controlled ports to minimize plumbing. The regulators electronically control pressure or vacuum by accepting a command signal of either 0-10 V or 4-20 mA. Pneumatic output is linear to command input. Analog output of 0-10 V is standard.
Proportion-Air Inc.
(317) 335-2602
www.proportionair.com
