Compressed air filtration
Extractor/Dryers efficiently remove moisture and contaminants to improve and extend the life cycle of tools and equipment. Twostage filters operate most effectively within 25 ft of the point of use. They offer a standard 5-μm rating with lower ...
Extractor/Dryers efficiently remove moisture and contaminants to improve and extend the life cycle of tools and equipment. Twostage filters operate most effectively within 25 ft of the point of use. They offer a standard 5-μm rating with lower ratings available, and feature flow ranges of 15 to 2000 scfm and pressure ratings of up to 250 psi. Differential pressure gauge provides a visual indication of required maintenance. Weep drain allows for continual discharge of condensate. La-Man Corp., (800) 348-2463, www.laman.com
