Mini low-pressure regulators
Ultra-miniature pressure regulators have a maximum width of 1 1 /32 in. and maximum height of 1 in. They weigh 26.5 g (brass) and 15 g (aluminum). Control output pressures from 0 to 30 psig, and are especially suited to low-pressure regulation, ...
Ultra-miniature pressure regulators have a maximum width of 1 1 /32 in. and maximum height of 1 in. They weigh 26.5 g (brass) and 15 g (aluminum). Control output pressures from 0 to 30 psig, and are especially suited to low-pressure regulation, such as 0.5 psig. Maximum rated inlet supply pressure is 300 psig. Inlet and outlet ports are tapped 10-32 UNF. Also available in stainless steel.
Beswick Engineering Co. Inc.
(800) 354-5014,
www.beswick.com
