Pilot-operated regulator
Edited By Mary C. Gannon High-relief, pilot-operated regulator for high-flow applications consistently maintains optimal system pressure. Available in 1/4 to 1 1/4 in. port sizes, it is in-line mounted. Its diaphragm design handles a maximum inlet ...
High-relief, pilot-operated regulator for high-flow applications consistently maintains optimal system pressure. Available in 1/4 to 1 1/4 in. port sizes, it is in-line mounted. Its diaphragm design handles a maximum inlet pressure of 400 psig, outlet pressure to 250 psig and accommodates flow rates exceeding 400 scfm. Full-size relief port provides high-pressure relief to 200 scfm. Pressure gauge and non-relieving configuration are optional.
Ross Controls, (800) 438-7677, www.rosscontrols.com
