Disposable Desiccant Breathers
SVDB series of disposable desiccant breathers for mobile and in-plant applications provide a low maintenance solution for moisture control. Two sizes — SVDB-093 and SVDB-096 — use non-toxic Z-R gel. They absorb water for a dry reservoir and ...
SVDB series of disposable desiccant breathers for mobile and in-plant applications provide a low maintenance solution for moisture control. Two sizes — SVDB-093 and SVDB-096 — use non-toxic Z-R gel. They absorb moisture, thereby keeping water out of the reservoir and also offer 10 μm particle filtration. Threaded design will not vibrate free in mobile applications. A ¾ in. NPT male (BA-5A) adapter is available.
Stauff Corp., (201) 444-7800, www.stauffusa.com
Click here to download a PDF datasheet.
