Air breather tester
Air Breather Check test system measures air breather effectiveness. It activates when vacuum equivalent of 15 in. water is reached. Visual indication shows activation. It resets by push-button and can be reused several times. It includes an adapter with splash guard and can be installed using optional fittings or low-pressure hose.
Schroeder Industries, (724) 318-1100, www.schroederindustries.com
