Reservoir air drying system
Edited By Mary C. Gannon ARV Active Reservoir Vent is a dry air purging system for minimizing water contamination in fluids. It continuously supplies dry air to reservoirs and other vented components, providing longer component life, extended fluid ...
ARV Active Reservoir Vent is a dry air purging system for minimizing water contamination in fluids. It continuously supplies dry air to reservoirs and other vented components, providing longer component life, extended fluid change intervals, and greater system uptime and reliability. Two Ultrapac models are rated for 3 and 10 scfm for up to 600 and 2000 gal reservoirs, respectively. Operating pressure is 100 psig. Both models come with a 1/2-in. NPTF connection. ARV Kit breather assembly is designed for up to 300 and 1000 gal reservoirs with 1 in. NPTF connection.
Donaldson Co. Inc.
(800) 846-1846
www.donaldson.com
