Breathers, strainers
Breathers, strainers Vickers-brand H20-reservoir vent breathers filter out dirt and moisture particles from incoming air in hydraulic systems. Mini Mobile-gate fits tight clearances on mobile equipment and Dirtgate filters out dirt in ...
Vickers-brand H20-reservoir vent breathers filter out dirt and moisture particles from incoming air in hydraulic systems. Mini Mobile-gate fits tight clearances on mobile equipment and Dirtgate filters out dirt in low-humidity environments. Vickers suction strainers prevent particles from traveling from reservoir to pump. They mount on reservoir’s interior or exterior and are offered with or without a visual indicator that shows element is clogged. Eaton Corp., Hydraulics Operations,
(952) 974-7727, www.hydraulics.eaton.com
