Valve Manifolds
Sub-miniature manifolds for 10- and 15-mm solenoid valves allow for groupings of valves in very small spaces. Single-sided units are available with 2, 4, 6, 8, 10, 12, 14, and 16 stations. They feature a common inlet, individually ported ...
Sub-miniature manifolds for 10- and 15-mm solenoid valves allow for groupings of valves in very small spaces. Single-sided units are available with 2, 4, 6, 8, 10, 12, 14, and 16 stations. They feature a common inlet, individually ported outlets, and exhaust to atmosphere. Configurations include normally open and normally closed. Dual supply ports are standard on longer manifolds for high capacity flow.
Clippard Instrument Laboratory Inc.
(877) 245-6247
www.clippard.com/10-15mm
