Hydraulic cartridge valves
Final stage uni-directional servo throttling cartridge valve has pressure rating to 5000 psi in 50, 80, and 100 mm sizes. It installs in DIN 24342 cavity and controls hydraulic flows to 4000 gpm.
Cartridge valves control pressure, flow, and direction in sizes from 2 to 4 in. for flows to 5,000 gpm. Pressure rating is 6,000 psi. Compact design fits standard DIN 24342 cavity. Options include various mounting patterns for  pilot valve; special materials; internally or externally piloted and drained. Can be designed with closing feature if power is lost.
Olmsted Products, (231) 929-1660, www.olmstedproducts.com
