Proportional pressure regulating cartridge
Small, proportional pressure regulating cartridge is designed for pilot control of directional valves and is a 2-position, 3-way bottom cylinder port. It accomodates flows to 0.5 gpm and input pressure to 3000 psi with regulated pressure to 320 ...
Small, proportional pressure regulating cartridge is designed for pilot control of directional valves and is a 2-position, 3-way bottom cylinder port. It accomodates flows to 0.5 gpm and input pressure to 3000 psi with regulated pressure to 320 psi. Offering low hysteresis and manual override, the one-piece housing ensures internal concentricity. The coil is waterproof, hermetically sealed, and requires no O-rings.
Sterling Hydraulics Inc., (847) 690-1333, www.sterling-hyd.com
