Explosion-proof valves
Line of explosion-proof, potted coils employ electroless nickel plating to achieve corrosion resistance to NEMA 4X. Available on entire line, from series 50 miniature valves to series 20 two-and three-way valves. Pressures from 0 to 3000 psi, ...
Line of explosion-proof, potted coils employ electroless nickel plating to achieve corrosion resistance to NEMA 4X. Available on entire line, from series 50 miniature valves to series 20 two-and three-way valves. Pressures from 0 to 3000 psi, with temperature ranges from 0° to 221° F. Designed for hazardous locations Class I, Groups A, B, C, and D, and Class II, Div. 1, Groups E, F, and Div. 2, Groups A, B, C, D, E, F, and G.
Peter Paul Electronics Co. Inc., (860) 229-4884, www.peterpaul.com
