Prefill valves
Product brochure includes complete technical information and specifications for PV, VPE, and SPE prefill and exhaust valves, including dimensions, weights, and expected performance data. Different sizes of twoway seated valves are similar in design, construction, and operation. Available in sizes from 40 to 450 mm, with peak pressures of 4568 to 10,150 psi. Accommodate oil, synthetic, and water-based fluids.
The Oilgear Co., (414) 327-1700, www.oilgear.com
