Product release: Self-contained filter cart
Model BFC 553 filter cart allows cleaning and transferring of petroleum-based fluids at a work site. It is designed to remove contamination as fluids are transferred from a drum and “polish” fluids in existing system. Its dc motor operates from an on-board rechargeable power supply, so it does not require an external power source. It can also be plugged into a 115-V power supply.
Model BFC 553 filter cart allows cleaning and transferring of petroleum-based fluids at a work site. It is designed to remove contamination as fluids are transferred from a drum and “polish” fluids in existing system. Its dc motor operates from an on-board rechargeable power supply, so it does not require an external power source. It can also be plugged into a 115-V power supply. It has a 5 gpm flow rating and can clean and transfer up to 225 gal of hydraulic fluid on a single charge..
Seven North Industries Inc.
(860) 355-4429
http://bit.ly/hp0112sevennorth
