Hydraulic Fluid
Shell Tellus Oil STX multigrade, zinc-free, ashless hydraulic fluid offers high shear stability, formulated with Group II base oils and additives. It tolerates a wide temperature range and has viscosity index of 160 to reduce the number of ...
Shell Tellus Oil STX multigrade, zinc-free, ashless hydraulic fluid offers high shear stability, formulated with Group II base oils and additives. It tolerates a wide temperature range and has viscosity index of 160 to reduce the number of required fluid grades. Fast start-up can be achieved through low temperature performance, while improved equipment protection and retention of fluid viscosity properties during operation can be expected.
Shell Lubricants
(800) 231-6950
www.shell-lubricants.com
