Long-running fluid
Hydrex hydraulic fluid keeps equipment running long and efficiently. It lasts three times longer and provides two times better wear protection than similar fluids. It helps extend drain intervals for reduced change-outs, thereby reducing ...
Hydrex hydraulic fluid keeps equipment running long and efficiently. It lasts three times longer and provides two times better wear protection than similar fluids. It helps extend drain intervals for reduced change-outs, thereby reducing reservoir exposure to external contaminants. Sludge and varnish formation are minimized for smoother equipment performance and reduced maintenance.
Petro-Canada Lubricants,
(905) 804-3600, www.petro-canada.com
