Anti-wear oils
Tellus Premium oils' anti-wear system offers reduced valve and actuator sticking and failure, high system efficiency, and prolonged pump and fluid life. They deliver thermal, hydrolytic, and oxidative stability to resist the formation of ...
Tellus Premium oils' anti-wear system offers reduced valve and actuator sticking and failure, high system efficiency, and prolonged pump and fluid life. They deliver thermal, hydrolytic, and oxidative stability to resist the formation of deposits for a smooth-running system. They also improve filtration system efficiency and separate water. Air release minimizes pump cavitation and oxidation degradation.
Shell Lubricants,
(800) 840-3806, www.shell-lubricants.com/hydraulics
