Dongguan Easytech Automation Mechanical and Electrical Equipment Co., Ltd.
Room 403, No. 212, Zhongxing Rd, Dalingshan,
Dongguan, Guangdong 523820
China
+8613537271735
More Info on Dongguan Easytech Automation Mechanical and Electrical Equipment Co., Ltd.
Easytech supplies vacuum cups, suction heads, vacuum lifters, glass installation robots, industrial manipulators and jib-crane systems for glass, sheet-metal and packaging material handling.
Products
Courtesy of Dongguan Easytech Automation Mechanical and Electrical Equipment Co., Ltd.
Elongated Bag And Box Vacuum Suction Head; Official Series Reference Image
Easytech ET-VC-PAD-BAG-180 is an elongated vacuum suction head for bags and boxes, with a 180 by 370 mm contact footprint. It mounts at the lifting-tube end and has no independent...
Four Pad Panel Suction Head; Official Series Reference Image
Easytech ET-VC-PAD-SHEET-4 is a sheet-handling suction head with four 140 by 370 mm pads. The head mounts at the lifting-tube end and uses the connected lifting system as its ...
ET-VC-PAD-BEL-140 Bellows Vacuum Cup for Boxes
Easytech ET-VC-PAD-BEL-140 is a 140 mm bellows vacuum cup for box-handling heads. The component has no independent power source and is used at the lifting-tube end. Selection ...
Contacts
Jenny Zhan
Dongguan Easytech Automation Mechanical and Electrical Equipment Co., Ltd. Categories
Request More Information From Dongguan Easytech Automation Mechanical and Electrical Equipment Co., Ltd.
