HORV rodless cylinders are short, thin, and light. Flat piston creates 40% thinner profile. Block-type end cap eliminates need for mounting brackets and reduced zero stroke results in dead stroke that is 35% shorter than band-type cylinders. ...
HORV rodless cylinders are short, thin, and light. Flat piston creates 40% thinner profile. Block-type end cap eliminates need for mounting brackets and reduced zero stroke results in dead stroke that is 35% shorter than band-type cylinders. Comes with stainless-steel seal band for long life and low leakage. Available with NPT ports.
