Quiz on Chapter 16: Accumulators
1. A weight-loaded accumulator: loses pressure as fluid discharges gains pressure as fluid discharges stays at the same pressure as fluid discharges 2. A spring-loaded accumulator: loses pressure as fluid discharges gains pressure as ...
  1. loses pressure as fluid discharges
  2. gains pressure as fluid discharges
  3. stays at the same pressure as fluid discharges
3. Gas charged accumulators use:
  1. oxygen
  2. nitrogen
  3. argon
4. The most common accumulator application is:
  1. supplementing pump flow
  2. making up for system leaks
  3. providing an emergency power supply
5. Precharge pressure should be checked at least every:
  1. one to two months
  2. two to three months
  3. three to six months
6. An accumulator may be used to:
  1. make a pump run faster
  2. make a valve shift more quickly
  3. make up for system leaks
7. Accumulator pre-charge pressure is normally.
  1. 95% of minimum system pressure
  2. 85% of minimum system pressure
  3. 75% of minimum system pressure
8. When the pump is running, an accumulator dump valve keeps fluid:
  1. from going to the accumulator
  2. from going to the circuit
  3. from going to tank
9. An unloading relief valve sends:
  1. pump flow to tank at system pressure
  2. accumulator flow to tank at system pressure
  3. pump flow to tank at 25 to100 psi
10. This symbol represents a:
  1. weight-loaded accumulator
  2. gas-charged accumulator
  3. spring-loaded accumulator
