Full power hydraulic brake system with ABS provides shorter stopping distance with improved vehicle stability and control during aggressive braking situations. System employs brakes, tandem modulating pedal valve, accumulator charging system, ...
Full power hydraulic brake system with ABS provides shorter stopping distance with improved vehicle stability and control during aggressive braking situations. System employs brakes, tandem modulating pedal valve, accumulator charging system, and dual accumulators. Speed sensors monitor wheel speed. ABS electronic control unit sends current to ABS valves when wheel slip occurs. Electrohydraulic ABS valves control pressure.
