Pneumatic valves
Low-power Isonic V2 direct-acting, solenoid-operated valves are available in normally-open and normally-closed configurations. They can be used to control vacuum and positive pressures at flow rates up to 0.05 CV. Molded from high-performance thermoplastic, they provide heat, impact and moisture resistance. It reduces power consumption by 60%, extending the life of battery-operated equipment and lowering costs.
heat, impact and moisture resistance. They reduce power consumption by 60%, extending the life of battery-operated equipment and lowering costs. Quick-connect manifolds are available in 4 or 8-station, with a single electrical sub-D connection.
Each valve weighs 1.5 oz. features a lightweight, high-strength polymer construction, combined with expanded voltage options, for a versatile, long-lasting energy efficient solution. It is available in 3 or 5 Vdc voltages
Improved features also ensure safety and adaptability for use in a variety of environments.
Bimba Manufacturing Co., (708) 534-8544, www.bimba.com
