Pneumatic valves
W66 ISO 15407-2 five-ported, pneumatic valves are available in standard configurations, such as 2-position, single solenoid and double solenoid, as well as 3-position open center, closed center, and power center functions. The 18-mm size ...
W66 ISO 15407-2 five-ported, pneumatic valves are available in standard configurations, such as 2-position, single solenoid and double solenoid, as well as 3-position open center, closed center, and power center functions. The 18-mm size 00 comes with ports and 0.55 CV, while the 26-mm size 0 has … ports with 1.1 CV. Manifold stations plug together electrically with integrated mating connectors. They integrate with DeviceNet, ControlNet, Ethernet I/P, and Profibus-DP systems.
Ross Controls, 800-438-7677, www.rosscontrols.com
Circle 162
