Pneumatic Valves
HK5 series direct-acting solenoid valves offer low leakage and inert construction for air, vacuum, and other gases or liquids. They are 12.6-mm wide, with a high 0.05-CV flow rate, low 1.7-W power consumption, a pressure rating from vacuum to ...
HK5 series direct-acting solenoid valves offer low leakage and inert construction for air, vacuum, and other gases or liquids. They are 12.6-mm wide, with a high 0.05-CV flow rate, low 1.7-W power consumption, a pressure rating from vacuum to 100 psig, and a working temperature range from 32° to 175°F. They feature multiple porting configurations, can be used as a 2-way or 3-way, NC/NO standard fill/exhaust valve, or as a selector.
Humphrey Products Co.
(269) 381-5500
www.humphrey-products.com
