Char-Lynn H, S, and T series spool valve motors come in nickel-plated models for corrosion protection in wash-down applications. They combine valving and hydrodynamic journal bearings in a common shaft design and provide high torque at ...
Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 04 01 2008 79777 Nickelplat 00000052241
Char-Lynn H, S, and T series spool valve motors come in nickel-plated models for corrosion protection in wash-down applications. They combine valving and hydrodynamic journal bearings in a common shaft design and provide high torque at low speeds and instant shaft reversal by simply changing direction of input/ output flow through the motor. Benefits include high efficiency and power-density, infinite bearing life at rated loads, and extended shaft seal life.
