Corrosion-resistant shock absorbers
Weartec Plus standard corrosion protection is available on industrial shock absorbers and feed controller threaded outer tubes for washdown and outdoor environments. Independent laboratory salt-spray testing shows that its corrosion ...
Weartec Plus standard corrosion protection is available on industrial shock absorbers and feed controller threaded outer tubes for washdown and outdoor environments. Independent laboratory salt-spray testing shows that its corrosion protection is 30% higher than platinum, Armaloy, and nickel plate; 67% higher than hard chrome; and 150% higher than black oxide.
Ace Controls Inc., (800) 521-3320, www.acecontrols.com
