Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 02 01 2008 78388fancooledj 00000051022
Fan-cooled exchangers
Feb. 13, 2008
Airtech fan-cooled units suit mobile and industrial applications where cooling requirements are remotely located, cooling water is unavailable or impractical, or where coolant is subject to freezing. All-aluminum vacuum brazed bar and plate ...
Airtech fan-cooled units suit mobile and industrial applications where cooling requirements are remotely located, cooling water is unavailable or impractical, or where coolant is subject to freezing. All-aluminum vacuum brazed bar and plate construction provides heat transfer efficiency in a compact, and light weight package. They are suitable for use as oil coolers and air aftercoolers. Eight model sizes provide a range of capacities in ac and dc versions.
API Heat Transfer,
(877) 274-4328,
www.apiheattransfer.com
Time-sensitive networking offers many advantages to industrial automation applications but certain factors need to be considered when implementing the technology.
Nov. 16, 2020
Pressure control is achieved in hydraulic systems by metering the flow of a fluid into or out of a constrained volume.
